ADUB Posted May 6, 2019 Report Share Posted May 6, 2019 Rack has a leak gearbox side at pipe bracket metal pipe or union what size is bolt cant seem to get anything to fit Quote Link to comment Share on other sites More sharing options...
Sausage Posted May 6, 2019 Report Share Posted May 6, 2019 Try imperial sockets if the nut has shrunk from rust. very likely a 10mm use a hex socket. 1 Quote Link to comment Share on other sites More sharing options...
ADUB Posted May 6, 2019 Author Report Share Posted May 6, 2019 Thanks I have tried all sizes car is on a small ramp will get it down and have good look,,been sat for nearly 4 years runs great think time to scrap Quote Link to comment Share on other sites More sharing options...
Sausage Posted May 6, 2019 Report Share Posted May 6, 2019 Actually scratch that, I just went and checked it is a very shallow 13mm. Socket wont work unless you grind the end flatter as they have a bevel for easier location. 1 Quote Link to comment Share on other sites More sharing options...
weslangdon Posted May 6, 2019 Report Share Posted May 6, 2019 Be prepared to cut the pipe to get it off, it can probably be repaired at Pirtek but not always, each model seems to be a little different and aren't always compatible but this is not a good reason to scrap the car. 1 Quote Link to comment Share on other sites More sharing options...
ADUB Posted May 6, 2019 Author Report Share Posted May 6, 2019 Was Daughters car would be a good car for someone spent good money on it then she bought a new up, Quote Link to comment Share on other sites More sharing options...
