Lupo sdi exhaust diameter
Dizzy_PD
Hi
As per title really, my exhaust has broken between the flexi and the cat. Considering just cutting it out and straight piping the downpipe.
Anyone know the diameter pipe needed for the downpipe? I didn't think to measure when I had on the ramp, sadly don't have access to that ramp now.
Tia
50mm. Get a whole new system from germany for £115 delivered. But you will need a new cat. Check your previous mot emissions data. If they tested to 0.7 (same as mine), you'll need the cat. If tested to 2.5 you'll be ok without it...
Thanks mate, so it's basically a 2" system.
Car's not worth enough to spend that much on new exhaust, I'll probs just weld in a piece in replacement of the cat, mot shouldn't be a problem.
Cheers
