GasWeedorAss Posted April 12, 2019 Report Share Posted April 12, 2019 (edited) Hello fellas, I recently bought a 1.4 Lupo left hand drive and I've never heard an alert when I leave the lights on when doors open/key out of the ignition The inside roof light works as meant to be (turns on when key out of the ignition or any door open) but no alert is played when I leave mediums/presence light/maximums ON with ignition OFF/no key on it Any idea how to fix this? Since I have no idea if this has anything to do with the fuses, I'll post 2 pics of the fuse box (also, tell me if something is missing please) Thanks in advance! Edited April 12, 2019 by GasWeedorAss Quote Link to comment Share on other sites More sharing options...
Rich Posted April 12, 2019 Report Share Posted April 12, 2019 Door microswitch. Does it beep when you open the passenger side? Quote Link to comment Share on other sites More sharing options...
GasWeedorAss Posted April 12, 2019 Author Report Share Posted April 12, 2019 (edited) 9 minutes ago, Rich said: Door microswitch. Does it beep when you open the passenger side? No signal. Nothing Where can I find the microswitch? Is it built in inside the door locker? The thing is that everything is working except the warning sound... If the interior light works I guess the door's mechanism is OK :\ Edited April 12, 2019 by GasWeedorAss Quote Link to comment Share on other sites More sharing options...
mk2 Posted April 12, 2019 Report Share Posted April 12, 2019 Does it make a sound when you leave the lights on and remove the ignition key? it should... Quote Link to comment Share on other sites More sharing options...
GasWeedorAss Posted April 12, 2019 Author Report Share Posted April 12, 2019 (edited) 8 minutes ago, mk2 said: Does it make a sound when you leave the lights on and remove the ignition key? it should... That's the problem. It should make the sound but it doesn't! Lights on, open door(any door) with key OUT of the ignition NO SOUND Edited April 12, 2019 by GasWeedorAss Quote Link to comment Share on other sites More sharing options...
mk2 Posted April 12, 2019 Report Share Posted April 12, 2019 Instrument cluster fault... Quote Link to comment Share on other sites More sharing options...
GasWeedorAss Posted April 12, 2019 Author Report Share Posted April 12, 2019 1 minute ago, mk2 said: Instrument cluster fault... Any possible fix? Quote Link to comment Share on other sites More sharing options...
mk2 Posted April 12, 2019 Report Share Posted April 12, 2019 New chip... soldering needed. Tricky. Easier to change cluster. Quote Link to comment Share on other sites More sharing options...
GasWeedorAss Posted April 12, 2019 Author Report Share Posted April 12, 2019 1 hour ago, mk2 said: New chip... soldering needed. Tricky. Easier to change cluster. Aight, thanks! Quote Link to comment Share on other sites More sharing options...
GasWeedorAss Posted April 14, 2019 Author Report Share Posted April 14, 2019 On 4/12/2019 at 6:12 PM, Rich said: Door microswitch. Does it beep when you open the passenger side? if one of the microswitches has passed away does it affect the warning sound of lights on with no key on the ignition? I found out the one from passenger's door is not turning the interior light on when door's open Quote Link to comment Share on other sites More sharing options...
Rich Posted April 14, 2019 Report Share Posted April 14, 2019 Yes Quote Link to comment Share on other sites More sharing options...
