Drivers door module replace
Darran
Hi all I’m after instructions on how to replace drivers side door module I’ve tried looking but have had no luck on seem to find golf but appreciate it if someone can help me out thanks
The module is pretty much the same as Mk4, getting to it is different, but its pretty easy to work out.
I find this you tube guy pretty good, music is not my taste, but he explains things well
Just make sure you close up any holes you make in the foam inner liner - this stops water getting in side the car. duct tape is good for this.
It's really not that hard but without a video demonstrating I can understand why you feel it would be. Perhaps this is a reason to resurrect my How To side.
@Rich 😂?
  • 1 year later...
Ordered one of these for my drivers door, as its been on the way out for a while 'No lights left on tone' 'car relocking after 30 seconds with the door open' which i could live with. But now the drivers door doesn't unlock with the fob which I can't be doing with so I'm finally replacing it. I've looked at a few golf tutorials, and i know about only loosening the lock retaining screw. So it should be pretty straightforward, right?
