Headlight bulbs
Darran
Hi all I been busy going around my lupo I replaced interior bulb and number plate bulbs with LED ones nice and bright so I would like to know if anybody has a link for bright clear bulbs for front lights and reverse bulbsĀ
The interior lamp has a dimmer circuit on it. It'll probably not work. When I got one of my SDIs, it had an LED lamp in there and was rubbish. Swapped it for a regular one and it worked again. Tested the LED once out- nothing wrong with it, so I can only suspect that the dimmer driver is designed for regular power hungry filament bulbs.
I have an LED interior bulb in mine (a 265 bulb) and it's dims the same as a normal bulb does
The front lights are just 501 bulbs, loads available on the net or even halfrauds, reverse lights are 382 bulbs, again loads on the net
