QuentinHW2909
No Check Engine Light
My car failed it’s mot for having no illumination of the Check engine light. it didn’t come on when i turn the ignition. so I’ve since disconnected the O2 sensor to try and purposely illuminate it. it still didn’t come on. so I switched the dashboard for another and tried again. still nothing happened. so what could I be missing? i’ve checked all the fuses and they’re all fine. any help at this point would be greatly appreciated 👍
Sounds like you have a Halfords or Kwik fit mot.
That's the biggest problem.
No it’s a Private Garage owned by a friends dad
1 hour ago, Sausage said:
You asked about this before:
yeah I did... but it had passed many previous MOTs without it coming up so I was just digging a bit deeper into it
If it passed emissions then it isn't even relevant.
Raise a case with dvsa and get your money back :)
 Might be a bit late for an appeal as he has had it in bits since then, but yes you should have appealed it on that failure.
This was an incorrect MOT failure.
