Darran Posted March 13, 2019 Report Share Posted March 13, 2019 I have VW Lupo 1.7sdi s it has all toys including sunroof problem is when it rains I pull off and a trickle of water comes in left hand front corner headliner so far I’ve pulled headliner down and made sure the blue drain pipe is connected I also checked drain point when door open I then filled sunroof tray up with water and all was ok draining through drain plug bottom of A pillar no leaks but when it rains it has a slight trickle then stops I’ve also cleaned scuttle and behind front wheel arch liners while I had the time Quote Link to comment Share on other sites More sharing options...
Rich Posted March 13, 2019 Report Share Posted March 13, 2019 I'd still say sunroof drains. Quote Link to comment Share on other sites More sharing options...
Darran Posted March 13, 2019 Author Report Share Posted March 13, 2019 Hi rich I pulled headliner down and poured water in tray and nothing leaked lol so what you wrecon is have another look at Quote Link to comment Share on other sites More sharing options...
mk2 Posted March 13, 2019 Report Share Posted March 13, 2019 Could be a rust hole in one of the roof channels. Known problem where the spray booth missed the outside edges.... lift out from the back without bending them to inspect. Quote Link to comment Share on other sites More sharing options...
Darran Posted March 13, 2019 Author Report Share Posted March 13, 2019 Yes I check tomorrow I’m also wondering would it be corner top of front windscreen ? Just trying to get it sorted Quote Link to comment Share on other sites More sharing options...
Darran Posted March 14, 2019 Author Report Share Posted March 14, 2019 Hi rich I just had headliner back down I double checked the drain pipe and all clear I did find a leak Which seems to drip from front corner of the black sunroof tray just on the inside corner by the blue drain pipe close to wear the sunroof wind bar screw is located if you can work out west I am lol i tried some double tape on it but no god so for now I used grease fingers crossed for now untill I find a permanent solution Quote Link to comment Share on other sites More sharing options...
