Darran
Lupo central locking issue
Hi all my 53 reg lupo 1.7Sdi s will open all doors and the interior light comes on when I put key in drivers door to open but when I try to lock it only the drivers door will lock but if I press central locking button on drivers door door card it works does anybody know what could be problem
Classic door locking switches problem. Every vdub, all models suffer from those problems, 97-2009 approx. Use your remote central locking instead.
oh, and welcome to club lupo :)
show us some pics of your SDI...
The OP's message is a bit confusing. Are you saying the passenger door doesn't lock from the central locking? @mk2 - remote locking wouldn't fix this. I'd replace the door module personally. It used to be cheaper to take them apart clean them up, and refresh any bad solder joints. I don't think it's worth it these days.
Hi Skezza if I put key in drivers door to open they all work fine and interior light comes on but when I turn key in drivers door to close only the drivers door. Closes the passenger side and boot stay open
Yeah that's the microswitch. When the key moves to the 'lock car' position, only the mechanical lock is working, but it's not being picked up by the convenience centre unit- the CCU is not getting the lock activation signal from the lock (switch) when you turn the key.
If you fitted an aftermarket RKE system, you can bypass the lock switches.
But like @Skezza says, it is possible that the 'locked' switch is faulty (different switch), in which case the CCU thinks that even though it provided a lock motor pulse to power the locking motor to lock the doors, it isn't getting confirmation that the motor worked. So it then unlocks the door again... It is a common fault. And a right pain to fix. Time consuming.
Does that mean to fix this I need to replace door module if so would that mean passenger door lol👍
Just tried passenger side to lock and unlock and that side works it even sets the red LED light to work on drivers side door pin
so does this mean to fix it I need a drivers side module
It is the drivers lock module, depending how capable you are -  either replace the whole module or the just the broken component on the lock module
It is a common failure on VW of that age the microswitch can be sourced of ebay
Yes...
Hi all just woundering if there are any good contacts to do jobs on my lupo  in  S Wales valleys area
as idd like to get this door module replaced and prob few other jobs in future
Personally, I'd bung in an aftermarket RKE system. One of my SDIs has a dodgy driver's door lock module and the solution was to just not use the key to open and lock the car remotely. Exactly the same symptoms...
There's a good gearbox refurb chap in your area. Someone on here will remember who he is.
Other than door module, I'd do the EGR, cam belt, check filters, change gear oil, lube linkages, locks, hinges. SDIs are built to last a very long time. :)
Any pics of your motor?
Yeah got cam belt job booked in next week I’ll mention other jobs to
Regarding the EGR when you say on list of jobs do you mean take off and clean
Disable it... And divert the rocker cover breather through a tube down to the road. Block off the plenum hole.
