Hi All,
Just thought I'd share this incase anyone is wanting to upgrade to 280mm brakes up front (Should apply to TDIs, 100HP 16v and GTI Models)
As most of you probably know, all that's needed is new carriers, discs and pads to do the upgrade, the stock caliper is fine.
Autodoc are currently stocking G60 carriers by Mapco for £24 a side plus postage, non OEM, but new compatible and seems less than some of the used carriers go for.
Pics attached of part no and the carriers I received.
  • Thanks 1
51 minutes ago, Sausage said:
Need more pics. Sliders included?
Sliders were included yeah and I'll get some more any in particular? need to fit them, but they look like the right ones!
I just spent £120 on some mapco ones about 2 weeks ago 🙄🙄 typical!
Edited by Skajme
Any other angle really just couldn't see even a sniffter of a slider in your pic.😃
You can use standard GTI pads on a gti with the g60 discs, been doing this for years and never had any issues. I do need to find a decent supplier for g60 discs tho as they are obsolete from VW now (535 615 301)
Think the only difference may be is the G60 pads are little thicker due to the discs being slightly thinner.  I may be wrong though!
G60 pads are bigger because the caliper has clearance for more depth.
I get mine from Eurocarparts, I use a G60 reg then get them under the performance section👍🏼
Anyone know if MTEC are any good? They do some at a pretty decent price
A mate ran them on his MK5 GTI, warped 2 sets in less than 6 months🤷🏼‍♂️
I run Brembo 280mm discs.
That's a pass then, nice one!
I think we both would need 15" wheels to run these in our TDI's
I have g60 and black diamond disks in a box, since changing my disks and pads (still 256mm) brakes are massively improved so havent felt the need to try them so far.
FaceBook just reminded me I have run the Brembo OEM replacements for 5 years.
But it I replaced them in Dec with Brembo Max High Performance Brake Disc (Grooved Solid)
