ibrarali@hotmail.com Posted January 11, 2019 Report Share Posted January 11, 2019 (edited) Engine switch light dont go off, when i try to start the car, hence it does not start. I have to wait hour or so and try again to get it started Edited January 11, 2019 by ibrarali@hotmail.com Quote Link to comment Share on other sites More sharing options...
Rich Posted January 11, 2019 Report Share Posted January 11, 2019 Engine light shouldn't make a difference when starting the car. Quote Link to comment Share on other sites More sharing options...
mk2 Posted January 11, 2019 Report Share Posted January 11, 2019 There is a fault which is causing the problem. The light is there to let you know it is serious enough, so if you don't get it checked you might get stranded somewhere. Quote Link to comment Share on other sites More sharing options...
ibrarali@hotmail.com Posted January 11, 2019 Author Report Share Posted January 11, 2019 I am talking about green light . When you press brake pedal Quote Link to comment Share on other sites More sharing options...
mk2 Posted January 11, 2019 Report Share Posted January 11, 2019 Ah yes. Ghosts in the machine... Quote Link to comment Share on other sites More sharing options...
RAB Posted January 20, 2019 Report Share Posted January 20, 2019 When you start the car with the lever in S, you need your foot on the brake as this opens the clutch. If putting your foot on the brake doesn't change the status of the green light, you have a faulty brake switch. This will be confirmed by being able to start the car in N. RAB Quote Link to comment Share on other sites More sharing options...
mk2 Posted January 20, 2019 Report Share Posted January 20, 2019 (edited) It should start in N, irrespective of brake pedal I'd've thought. Unless there's a fault with the gearshift selector. I know what you mean now, now that @RAB has elaborated.... just thought, if you have to wait an hour, it could be accumulator pressure related. Is there a pressure sensor on the 3L system? Edited January 20, 2019 by mk2 Quote Link to comment Share on other sites More sharing options...
RAB Posted January 22, 2019 Report Share Posted January 22, 2019 Nothing to do with the accumulator. The green light goes out when the foot brake is pressed. Or in his case, should. RAB Quote Link to comment Share on other sites More sharing options...
mk2 Posted January 22, 2019 Report Share Posted January 22, 2019 In that case RAB is correct Quote Link to comment Share on other sites More sharing options...
