Tacho problems...
MORE
1 hour ago, MORE said:
Yes mk2, I mean exactly this. I though that,  using com vag, there was a way to upgrade or modify the tachometer.
Thanks.
Of course vagcom doesn't offer that service.
On 12/24/2018 at 8:22 PM, Skezza said:
I have done odometer corrections on Loops. Google Vag commander. Perfectly fine for non crypto clusters like the Lupo. Don't use on anything like an RB8 instrument cluster or you'll enter brick city.
Rich is correct. Immobilizer is a separate box. Clocks are independent. You can drive a Lupo without them.
Hello.
Due to my problem, I would buy one of the two cables.
1) Interface diagnostic OBDII VW HEX+K+CAN USB COM VAG
2) USB KKL VAG-COM 409.1
What is the best, please?
How I can download and use the vag commander, please?
BR
Hello.
BR
I can't really tell what the first of those cables actually is.... is it a fake Ross-Tech clone? It sure doesn't look like one, which means you could end up with some nasty thrown together software package or something. It looks a lot like a VAG Commander cable, but they don't specify whether it is or isn't. Personally, I think it would have been mentioned at least once, because most people who buy VAG Commander are doing it for 2 or 3 specific reasons and therefore, without mentioning it, people simply won't buy it.
The second is your bog standard 409.1 cable. Pretty much ideal for most people driving older VW's, including Lupo owners.
https://www.ebay.co.uk/itm/VAG-K-CAN-COMMANDER-1-4-Popular-VAG-Diagnostic-Tool-For-Audi-For-VW-For-Skoda-UK/223298005186?_trkparms=aid%3D555017%26algo%3DPL.CASSINI%26ao%3D1%26asc%3D55148%26meid%3D6331de2df9b44d63934b8b6e9998db02%26pid%3D100505%26rk%3D1%26rkt%3D1%26%26itm%3D223298005186&_trksid=p2045573.c100505.m3226
That is a VAG Commander cable. Just be aware that you can do serious damage with the cable above, if you're not careful. It's not like VCDS.
Ok, thanks a lot for yours tricks, I apologize, but regarding "old" obd protocol, I'm totally a real "dummy".
I am sorry to annoying the Club for my problems.
Many thanks.
M
