MORE Posted December 23, 2018 Report Share Posted December 23, 2018 Hello guys, I've a problem, better two... The first one, is that, trying to understand how to change bulbs in the tacho, because the light intensity is very poor, I discovered that... there are no bulbs, maybe somo leds fitted inside the tacho. So, remounting the connectors... the speedometer changed from zero Km/h to... below zero... May yo help me in some way? Thank you and sorry for my bad english... Have a nice day. Moreno Quote Link to comment Share on other sites More sharing options...
mk2 Posted December 23, 2018 Report Share Posted December 23, 2018 There is an adjuster next to the main light switch- next to the headlight position adjuster. Maybe it is loose? Try wiggling it.... Quote Link to comment Share on other sites More sharing options...
MORE Posted December 23, 2018 Author Report Share Posted December 23, 2018 52 minutes ago, mk2 said: There is an adjuster next to the main light switch- next to the headlight position adjuster. Maybe it is loose? Try wiggling it.... Hi, no, this works well. I know this dashboard, cos I had a 6n2 polo. Thanks Quote Link to comment Share on other sites More sharing options...
Skezza Posted December 23, 2018 Report Share Posted December 23, 2018 I would just replace the cluster. They cost pennies..... Quote Link to comment Share on other sites More sharing options...
mk2 Posted December 23, 2018 Report Share Posted December 23, 2018 Yeah, but how to correct for the odometer...? one of my SDI's cluster has a duff buzzer/gong thing, and it isn't the speaker. I have a spare working cluster, but the milage is 186k. My loop's only done 101k. I know absolutely no-one in the entire vdub universe that knows how to correct the odometer (or copy a key for that matter...). @MORE will have the some problem and in Italy they take milage changes very seriously. @Rich knows no-one either and he knows a lot of vdub geezers. Quote Link to comment Share on other sites More sharing options...
Rich Posted December 23, 2018 Report Share Posted December 23, 2018 Apparently it can be done but the clocks need to be sub 100k. Quote Link to comment Share on other sites More sharing options...
Rich Posted December 23, 2018 Report Share Posted December 23, 2018 Or so I heard. Quote Link to comment Share on other sites More sharing options...
MORE Posted December 23, 2018 Author Report Share Posted December 23, 2018 Mmm... I hope I understood well ... So, do you think it's a question of broken cluster? Thanks Quote Link to comment Share on other sites More sharing options...
mk2 Posted December 23, 2018 Report Share Posted December 23, 2018 54 minutes ago, Rich said: Or so I heard. Yeah, I know a few people who can unsolder the cluster memory chip then muck about with it. But, 90% of the time it ends up trashed and the other 10% of the time something else gets messed up. If someone ever cracks how to change dash settings or copy keys via the diagnostic socket they'll make some money... One guy I know told me he could copy a lupo key for £75, but couldn't guarantee me that he wouldn't break the cluster as he had to unsolder and resolder the memory chip to read the data. Which then turns it into a £350 main dealer problem. Mmmm. Quote Link to comment Share on other sites More sharing options...
MORE Posted December 23, 2018 Author Report Share Posted December 23, 2018 Tomorrow I will post photos to explain better... ok? Thanks Quote Link to comment Share on other sites More sharing options...
Rich Posted December 23, 2018 Report Share Posted December 23, 2018 Lupo key isn't related to the cluster Quote Link to comment Share on other sites More sharing options...
cj1 Posted December 24, 2018 Report Share Posted December 24, 2018 15 hours ago, Rich said: Lupo key isn't related to the cluster I wouldn't trust that guy. 18 hours ago, mk2 said: but couldn't guarantee me that he wouldn't break the cluster as he had to unsolder and resolder the memory chip to read the data. Quote Link to comment Share on other sites More sharing options...
Rich Posted December 24, 2018 Report Share Posted December 24, 2018 Lupo key codes to the transponder box like a MK3 golf. Go change your clocks and watch as the car starts. Quote Link to comment Share on other sites More sharing options...
MORE Posted December 24, 2018 Author Report Share Posted December 24, 2018 As you see, tachometer is below zero... Quote Link to comment Share on other sites More sharing options...
Rich Posted December 24, 2018 Report Share Posted December 24, 2018 You can pop them apart and recalibrate the needle if you're bored Quote Link to comment Share on other sites More sharing options...
MORE Posted December 24, 2018 Author Report Share Posted December 24, 2018 Did it... It doesn't work. The needle continue to go below zero... Poor me! Quote Link to comment Share on other sites More sharing options...
Rich Posted December 24, 2018 Report Share Posted December 24, 2018 Set it with the car running and the clocks plugged in albeit apart? Quote Link to comment Share on other sites More sharing options...
mk2 Posted December 24, 2018 Report Share Posted December 24, 2018 6 hours ago, Rich said: Lupo key codes to the transponder box like a MK3 golf. So I'm guessing he must have meant desoldering the chip in the transponder box? I personally don't like messing with stuff like that without lots of info... if it goes wrong, it ends up costing more than just having a dealer sort it before I've broken everything! interesting thing though, is that i know you can access the cluster AND the transponder box via the diagnostics port, with the Vdub VAS system. It is possible to recalibrate the fuel gauge, set tacho zero position, adjust the 90 degrees C point on the temp gauge using the vdub system- i watched it being done. Only thing I've not seen is a key being copied, or to be more correct- assigning keys to the car. I get the impression you need to put the metal cut key into the ign lock, have the sensor pick up the RF key ID transponder serial number, then assign that key to the car by storing the key Serial number in a memory location somewhere. So it's a 3 step process from having spoken to a lot of people. Learn. Read. Save. You can have up to 3 keys assigned to a car, which implies that there must be 3 memory locations- probably 4 bytes of data per key....? I need more info. @MORE , Tacho always going low suggests a faulty power bus in the cluster. From my experiments a few years back, I think it runs at -5v 0 +5v or something like that. The needle pointer gauges are all differential drive to isolate them from any main 12v feed fluctuations. Each gauge is driven through a chip, not direct from sensor. Quote Link to comment Share on other sites More sharing options...
Skezza Posted December 24, 2018 Report Share Posted December 24, 2018 I have done odometer corrections on Loops. Google Vag commander. Perfectly fine for non crypto clusters like the Lupo. Don't use on anything like an RB8 instrument cluster or you'll enter brick city. Rich is correct. Immobilizer is a separate box. Clocks are independent. You can drive a Lupo without them. Quote Link to comment Share on other sites More sharing options...
MORE Posted December 27, 2018 Author Report Share Posted December 27, 2018 On 12/24/2018 at 6:01 PM, Rich said: Set it with the car running and the clocks plugged in albeit apart? No.. I did it with the engine off and disconnect them... Quote Link to comment Share on other sites More sharing options...
Rich Posted December 27, 2018 Report Share Posted December 27, 2018 I'm on about being pikey while you do it. Quote Link to comment Share on other sites More sharing options...
MORE Posted December 27, 2018 Author Report Share Posted December 27, 2018 Gosh... Quote Link to comment Share on other sites More sharing options...
MORE Posted December 27, 2018 Author Report Share Posted December 27, 2018 Ok. I tried with engine on, put the needle to zero. Then, ignition on, start. Second prove... Disconnect key, ignition on... Needle below zero... Oh f@@k... Suggestions? I m getting crazy, thanks to everybody. M Quote Link to comment Share on other sites More sharing options...
mk2 Posted December 27, 2018 Report Share Posted December 27, 2018 Cluster fault. Quote Link to comment Share on other sites More sharing options...
MORE Posted January 4, 2019 Author Report Share Posted January 4, 2019 On 12/27/2018 at 6:56 PM, mk2 said: Cluster fault. Ok. I buy and changed the cluster. This works fine, but now I don't have anymore my old kilometers, but that was stored in this "new" cluster... Is it correct? BR Quote Link to comment Share on other sites More sharing options...
