Sausage
Bottom arms and bushes
Hard enough to get the camber right without messing on with arm length.
Also acceptable instead of a hydraulic press is some welded box and a bottle jack.
10mm longer could be 6n2 arms.
I used the lemforder from ecp on mine last year
The longer arms are same as on the red TDI, so I assumed standard but they might not be as he had silly camber and lows going on on it..
With a tape measure they are 36cm metal tip to centre of front bush. The shorter ones are 35cm metal tip to centre of front bush. There is some wiggle room on the joint mounts so the 10mm difference can have slight adjustment by a few mm.
Those LF are still £20 delivered.
Got some epoxy goop to glue the washers on now as want solid bond so will redo them.
Edited by Sausage
Looking at Vagcat, Only the Lupo gets a choice of arms, the Arosa only lists the longer one. The shorter one is shared with the 6N.
Maybe it is a 256 brake thing but then the arosa would have an option.
