rrdoctoruk
lupo tdi gearbox cables
need some help chaps
can someone measure the distance of the amount of thread showing on the gearbox change cables for me,
one on the left and one on the right,
changed to a newer gearbox tried to adjust to factory setting but will not let all gears be selected.
Strange question. Have you not tried the 5mm drill in the gearstick and locking the shift tower? I find the shift tower can be a bit awkward to get into the correct place but after that it's easy.
yes have done all of that but still cannot get all the gears
53 minutes ago, lupo 1.7sdi said:
I have attached the gear selector adjustment procedure. You need a pdf viewer.
adjusting gear selector.pdf
if this is the factory procedure have already done that,
link does not work I am afraid but I assume it is the same as the lupo factory manual,
Pikey spec time.
Unclick cables.
Click the tower into reverse.
Have someone hold the selector down and into reverse.
Click the cables back on.
