oldfudger Posted November 16, 2018 Report Share Posted November 16, 2018 Hi all my son has an engine light on on his 53 plate 1.0s arosa have scanned it and this comes up (see picture below) How do we proceed to cure problem without spending a fortune Thanks in advance for any help, much appreciated Quote Link to comment Share on other sites More sharing options...
Pete Posted November 16, 2018 Report Share Posted November 16, 2018 Isn’t P0441 to do with that charcoal canister for vapour fumes? I’d be checking that out first. 1 Quote Link to comment Share on other sites More sharing options...
oldfudger Posted November 16, 2018 Author Report Share Posted November 16, 2018 (edited) any pictures as to where that is positioned on car ? Edited November 16, 2018 by oldfudger Quote Link to comment Share on other sites More sharing options...
Pete Posted November 16, 2018 Report Share Posted November 16, 2018 If it’s like the gti it’l be offside next to the chassis leg near the inner wing. 1 Quote Link to comment Share on other sites More sharing options...
cj1 Posted November 16, 2018 Report Share Posted November 16, 2018 (edited) If it is the above, I have a 1.0 AUC Polo at home and would have one available. (All engine parts for that matter) Edited November 16, 2018 by cj1 1 Quote Link to comment Share on other sites More sharing options...
mk2 Posted November 16, 2018 Report Share Posted November 16, 2018 The first thing i'd try once located, is block the vapour feed from the canister into the vacuum side of the engine. It could be that the purge solenoid has jammed open, or is sticky. I generally bung a bolt in there and forget it. Blocked = no problems ever. 1 Quote Link to comment Share on other sites More sharing options...
oldfudger Posted November 24, 2018 Author Report Share Posted November 24, 2018 I cant find either of these parts, any pictures please, there is a same aged car in my local scrapyard, thanks Quote Link to comment Share on other sites More sharing options...
mk2 Posted November 24, 2018 Report Share Posted November 24, 2018 Show us a pic of the engine bay... Quote Link to comment Share on other sites More sharing options...
LR5V Posted November 24, 2018 Report Share Posted November 24, 2018 In the snip below - 1 is the rough location of the purge solenoid - you will see a pipe connecting to the - 2 is the carbon canister Quote Link to comment Share on other sites More sharing options...
oldfudger Posted November 25, 2018 Author Report Share Posted November 25, 2018 On 11/24/2018 at 9:06 PM, mk2 said: Show us a pic of the engine bay... Will get a picture on tomorrow, thanks Quote Link to comment Share on other sites More sharing options...
oldfudger Posted November 25, 2018 Author Report Share Posted November 25, 2018 23 hours ago, LR5V said: In the snip below - 1 is the rough location of the purge solenoid - you will see a pipe connecting to the - 2 is the carbon canister Brillant thanks - can No 2 be removed from above when light etc are in the way ? Quote Link to comment Share on other sites More sharing options...
mk2 Posted November 26, 2018 Report Share Posted November 26, 2018 You don't need to remove it... follow the hoses, in particular the one that goes into the inlet plenum that dumps fumes in to the engine. It'll probably go via a solenoid valve. That's the pipe you'll want to shut off. Quote Link to comment Share on other sites More sharing options...
LR5V Posted November 26, 2018 Report Share Posted November 26, 2018 (edited) I removed mine - it just slides up these slots and I capped off the solenoid with silicone cap and cable tie - routed the vent pipe into the wheel arch through one of the slots as you can see above Edited November 26, 2018 by LR5V Quote Link to comment Share on other sites More sharing options...
