Martycoo Posted November 16, 2018 Report Share Posted November 16, 2018 ☹️ car starts but wont go in gear any ideals thanks Quote Link to comment Share on other sites More sharing options...
cj1 Posted November 16, 2018 Report Share Posted November 16, 2018 (edited) 2 hours ago, Martycoo said: ☹️ car starts but wont go in gear any ideals thanks What have you tried thus far in diagnosing the problem? Essentially whether the car starts doesn't particularly matter at this point. The gear selector doesn't know if the car is running or not. Edited November 16, 2018 by cj1 Quote Link to comment Share on other sites More sharing options...
mk2 Posted November 16, 2018 Report Share Posted November 16, 2018 Shifter or linkages ok? Does the gear shift feel ok? Quote Link to comment Share on other sites More sharing options...
Rich Posted November 16, 2018 Report Share Posted November 16, 2018 Pedal box? Quote Link to comment Share on other sites More sharing options...
Martycoo Posted November 16, 2018 Author Report Share Posted November 16, 2018 2 hours ago, cj1 said: What have you tried thus far in diagnosing the problem? Essentially whether the car starts doesn't particularly matter at this point. The gear selector doesn't know if the car is running or not. gear stick wont budge was taking it to garage tomorrow ,i,m no mechanic so i haven,t got a clue Quote Link to comment Share on other sites More sharing options...
Martycoo Posted November 16, 2018 Author Report Share Posted November 16, 2018 1 hour ago, mk2 said: Shifter or linkages ok? Does the gear shift feel ok? i can run through the gears when engines off Quote Link to comment Share on other sites More sharing options...
Martycoo Posted November 16, 2018 Author Report Share Posted November 16, 2018 i can run through the gears when the engines off Quote Link to comment Share on other sites More sharing options...
Pete Posted November 16, 2018 Report Share Posted November 16, 2018 Gearbox/clutch side then. Quote Link to comment Share on other sites More sharing options...
mk2 Posted November 16, 2018 Report Share Posted November 16, 2018 Ok, so sounds like the clutch is not disengaging. The syncro rings cannot spin up or down to match the selected gear as theres too much friction. Pedal box. Read the gearbox thread... Quote Link to comment Share on other sites More sharing options...
Pete Posted November 16, 2018 Report Share Posted November 16, 2018 Usually if a pedal box goes tho you get a fair bit of prior warning before it gives up. Quote Link to comment Share on other sites More sharing options...
