Martycoo
clutch
2 hours ago, Martycoo said:
☹️ car starts but wont go in gear  any ideals thanks
What have you tried thus far in diagnosing the problem?
Essentially whether the car starts doesn't particularly matter at this point. The gear selector doesn't know if the car is running or not.
Edited by cj1
Shifter or linkages ok? Does the gear shift feel ok?
Pedal box?
gear stick wont budge was taking it to garage tomorrow ,i,m no mechanic  so i haven,t got a clue
i can run through the gears when engines off
Gearbox/clutch side then.
Ok, so sounds like the clutch is not disengaging. The syncro rings cannot spin up or down to match the selected gear as theres too much friction. Pedal box. Read the gearbox thread...
Usually if a pedal box goes tho you get a fair bit of prior warning before it gives up.
