Rokasgr
Lupo 3L fuel issue
Hello, i have a lupo 3L 1.2TDI and it have a average 6.5L/100km fuel consumption.
I have changed air filter. Engine sounds fine to me. Can someone help me, what should i check to fix this issue?
Edited by Rokasgr
Have you scanned it with VCDS? Can you manually move the turbo VNT mechanism? Wheel bearings OK? Coolant temperature sensor OK?
RAB
If any diesel car gives low economy, it is usually running a rich mixture (not enough air) or braking effort somewhere/high friction.
The computer will keep injecting the same fuel (it doesn't know there's a problem), but not enough air means black smoke, low power, bad economy. Hey, just thought... does the 3L have EGR? Could be stuck EGR?
Maybe no problem...? heavy right foot :)
When im trying to be aconomic as possiblr i can gey 5.5l/100km... there is a problem somewere. After changing oil, checking vnt,, changing sparkplugs and accumulator and fuel filter  i hope i get better resulys
Again, can you manually move the turbo VNT mechanism? Wheel bearings OK?
RAB
Huh?
