Scrooge Posted August 16, 2018 Report Share Posted August 16, 2018 I'm new on here so apologies if this has been asked before, what diameter hole is left in the door when the manual winder mechanism has been removed? I'm going to retro fit electric windows into my SE so need to source some plugs to fill the hole left in either door when doing the job. Can't make a start until I know the hole size. Cheers! Quote Link to comment Share on other sites More sharing options...
Scrooge Posted August 22, 2018 Author Report Share Posted August 22, 2018 Anybody?? Quote Link to comment Share on other sites More sharing options...
mk2 Posted August 22, 2018 Report Share Posted August 22, 2018 (edited) About 20mm at a guess. But what are you going to use? A rubber bung woukd be pants. Bit of gaffer tape? Or make a feature of it and bung some tweeters in there. Or adjustable led reading spot lamps? oh, and welcome to little club lupo world! Hey, just had a mad thought- you can get spring loaded double pole double throw with centre off panel mounting rocker switches (some even mount in a round hole). You could use those to make a manual electric window controller thing... Edited August 22, 2018 by mk2 Quote Link to comment Share on other sites More sharing options...
Scrooge Posted August 23, 2018 Author Report Share Posted August 23, 2018 Thanks for the info! I was going to get the correct size plastic bung and either leave it black, get them soft touch coated to match the handles and door pulls, or get them painted body colour. I’ve not decided yet. There is a 3L on eBay that’s had electric windows retro fitted and I don’t think it looks too bad with the bungs in place. I’ve already got some GTI door cards with switch cut outs to go into the car so no need to accommodate switches anywhere else. Quote Link to comment Share on other sites More sharing options...
