Pics of boot floors
Sausage
Thanks, anyone know the sport part number and prices for the new panels?
Guessing i'd have to chop the bottom out anyway on a sport well if i wanted a battery and skinny spare in there together, or find a teeny tiny battery?
It's a couple of hours work (by a competent welder, not a shaven ape like myself) to cut and adapt the standard boot floor to fit a centre exhaust and spacesaver wheel.
Be advised, if the new exhaust is of a larger bore than standard, it *may* end up catching on the brake lines and bias valve, and therefore need a bit of tweaking to fit.
Also the rear bumper needs notching for the tailpipe to fit.
Handily, I know a fella who does it, so if you're ever in the North Yorkshire area... :D
I'll most likely just mod the existing well, but would like it to look oem not DIY. So a factory panel if they are reasonable money could still be the way to go. Exhaust system will be large bore otherwise why bother.
Battery Relocated using a motamec ali battery tray.
The battery has been replaced now with a much larger version.
https://www.ebay.co.uk/itm/Motamec-Std-Size-Alloy-Car-Battery-Tray-Aluminium-Box-Holder-Black-Powder-Coated-/292161080417?hash=item4406284c61
  • 4 years later...
