Olgis93 Posted April 22, 2018 Report Share Posted April 22, 2018 Hi boys and girls. New here ? I have a lupo tdi 1.2L 3Lwith a bad gearbox i got in for free. Im thinking of changing gearbox but to a ”fully automatic” gearbox. Anyone here knows if there is some gearbox that is bolt on to this one? Thx for all answers ?? Quote Link to comment Share on other sites More sharing options...
mk2 Posted April 22, 2018 Report Share Posted April 22, 2018 welcome to club lupo! what is the problem you have with the gearbox? can you describe the fault? Quote Link to comment Share on other sites More sharing options...
Olgis93 Posted April 22, 2018 Author Report Share Posted April 22, 2018 Thank you! 5 th gear dosent work. but i want it to be fully automatic couse here in sweden they count it as Manuel shift and this car is perfect for my mother and i love lupo but she can only drive automatic cars couse she only has it on her drivings license. Quote Link to comment Share on other sites More sharing options...
RAB Posted April 23, 2018 Report Share Posted April 23, 2018 Why would they consider it a manual when it has no clutch pedal? It is fully automatic or semi-automatic, depending on the position of the gear stick. A manual it is NOT! RAB Quote Link to comment Share on other sites More sharing options...
Sausage Posted April 23, 2018 Report Share Posted April 23, 2018 Ok for stooging about in though, only need 5th on fast roads... unless it has nasty noises in which case dont drive it. Quote Link to comment Share on other sites More sharing options...
Olgis93 Posted April 23, 2018 Author Report Share Posted April 23, 2018 Well in sweden it count as Manuel i dont know why. I dont want to fix it, you guys dont know any automatic gearbox fit ? Quote Link to comment Share on other sites More sharing options...
Rich Posted April 23, 2018 Report Share Posted April 23, 2018 The physicality's are easy, what are you going to do for software ? Quote Link to comment Share on other sites More sharing options...
Olgis93 Posted April 23, 2018 Author Report Share Posted April 23, 2018 (edited) I have a mechanic doing everything, thats why I need some help.. what software can i use and What gear box and so on? Edited April 23, 2018 by Olgis93 Quote Link to comment Share on other sites More sharing options...
Skezza Posted April 23, 2018 Report Share Posted April 23, 2018 3 hours ago, Rich said: The physicality's are easy, what are you going to do for software ? The 1.2 TDi can be coded in VCDS to take a manual gearbox? Quote Link to comment Share on other sites More sharing options...
cj1 Posted April 23, 2018 Report Share Posted April 23, 2018 2 minutes ago, Skezza said: The 1.2 TDi can be coded in VCDS to take a manual gearbox? He doesn't want a manual box though.... On 4/22/2018 at 4:48 AM, Olgis93 said: Im thinking of changing gearbox but to a ”fully automatic” gearbox. Anyone here knows if there is some gearbox that is bolt on to this one? Quote Link to comment Share on other sites More sharing options...
mk2 Posted April 23, 2018 Report Share Posted April 23, 2018 i'll stick my neck out on this one, and say it is not possible to retro fit an autobox. well, not without a lot of work. Quote Link to comment Share on other sites More sharing options...
Blue Loop Posted April 23, 2018 Report Share Posted April 23, 2018 I've only ever seen 3L's converted to manual, never full-automatic... Quote Link to comment Share on other sites More sharing options...
RAB Posted April 30, 2018 Report Share Posted April 30, 2018 On 23/04/2018 at 6:34 PM, Blue Loop said: I've only ever seen 3L's converted to manual, never full-automatic... All 3L's are fully automatic, or semi-automatic! RAB Quote Link to comment Share on other sites More sharing options...
Blue Loop Posted April 30, 2018 Report Share Posted April 30, 2018 Exactly. That's why I said the only conversions I've seen are from an automatic gearbox (standard) to a manual one. Quote Link to comment Share on other sites More sharing options...
Derv Posted June 20, 2018 Report Share Posted June 20, 2018 On 4/30/2018 at 5:45 AM, RAB said: All 3L's are fully automatic, or semi-automatic! RAB All are originally automated manual, but the conversion to fully manual are relatively straightforward mechanically, as the 3L uses a manual clutch and gearbox. I'm going to guess that a automatic conversion could be tricky. Finding a torque converter and automatic gearbox bell housing to bolt up to the 3 cylinder TDI engine block are the key. The rest should be relatively easy. The 1.2 and 1.4 TDI in many ways is a chopped down 1.9TDI. I would start looking there for possible donors for automatic parts. Quote Link to comment Share on other sites More sharing options...
Rich Posted June 21, 2018 Report Share Posted June 21, 2018 I would look into the world of A2 tdi. but it isn't a simple task.... Quote Link to comment Share on other sites More sharing options...
Derv Posted June 21, 2018 Report Share Posted June 21, 2018 I don't think I've ever seen an A2 TDI with an automatic 'box either. Quote Link to comment Share on other sites More sharing options...
weslangdon Posted June 28, 2018 Report Share Posted June 28, 2018 the auto box on the petrol 1.4 only has 4 gears Quote Link to comment Share on other sites More sharing options...
