Mr.LDC Posted February 19, 2018 Report Share Posted February 19, 2018 Hi all, need to replace the front and rear wheel bearings on my Lupo. Any links and prices? Cheers, Luke Quote Link to comment Share on other sites More sharing options...
Rich Posted February 19, 2018 Report Share Posted February 19, 2018 rears are diy but the fronts are tricky. Quote Link to comment Share on other sites More sharing options...
mk2 Posted February 19, 2018 Report Share Posted February 19, 2018 For the fronts you need a hydraulic press. No options. I go down to our local machine shop armed with a box of chockies, icecream or beer depending on time of year and humbly ask if i may use their machine for half and hour (to do both). Have never had a no reply yet Quote Link to comment Share on other sites More sharing options...
Rich Posted February 19, 2018 Report Share Posted February 19, 2018 i do exactly the same, I can do a hammer install if I have to. Quote Link to comment Share on other sites More sharing options...
LR5V Posted February 20, 2018 Report Share Posted February 20, 2018 Front and rear bearings design are same as Mk4 Golf -Lots of You tube films out there I have my own cheap hydraulic press but this requires the hub removed form the car. There is a Wheel bearing removal tool that can remove and install the bearing with the hub on the car maintaining alignment. -sell the tool on after using Quote Link to comment Share on other sites More sharing options...
Mr.LDC Posted February 21, 2018 Author Report Share Posted February 21, 2018 Thanks for the help all, really appreciate it Quote Link to comment Share on other sites More sharing options...
mk2 Posted April 26, 2018 Report Share Posted April 26, 2018 On 20/02/2018 at 9:05 AM, LR5V said: There is a Wheel bearing removal tool that can remove and install the bearing with the hub on the car maintaining alignment. -sell the tool on after using never seen one of them... got info? Quote Link to comment Share on other sites More sharing options...
Rich Posted April 26, 2018 Report Share Posted April 26, 2018 by the time you have taken the shaft out and ****ed around doing it on the car you might as well remove the hub and take half the time. to remove the shaft you would have to have the BJ out anyways, you could save alignment by removing the one bolt and taking the strut off with the hub. Quote Link to comment Share on other sites More sharing options...
LR5V Posted April 26, 2018 Report Share Posted April 26, 2018 Admitedly it was a Mk4 I have seen them used hub on the car, no alignment changed Ebay wheel bearing removal kit - there may not be the same amount of room on our Lupo's Personally I also prefer the hub out, I have a cheap press and I use a Bearing race driver to push the bearing home Quote Link to comment Share on other sites More sharing options...
hoddlewaddle Posted June 18, 2018 Report Share Posted June 18, 2018 Got this to do tomorrow. If I remember I'll take a load of photos as I go, and maybe even put them into a vague chronological order, with notes. Quote Link to comment Share on other sites More sharing options...
Rich Posted June 18, 2018 Report Share Posted June 18, 2018 i did a mk4 with a hammer and no wire brush yesterday, bad times. Quote Link to comment Share on other sites More sharing options...
