Newlupo1 Posted February 12, 2018 Report Share Posted February 12, 2018 Hi everyone. got a slight problem with my 1ltr 99plate lupo. I need to change the throttle cable as its too far stretched for the adjustment. I have already got a new cable to swap with. How much of the internal panels and dash do i need to take off to get to the accelerator pedal to remove the cable? advice and help much appreciated. Quote Link to comment Share on other sites More sharing options...
Rich Posted February 12, 2018 Report Share Posted February 12, 2018 just the bottom panel and then you lie uncomfortably on your back with the phone torch pointed upwards. mostly you can just get away with loosening the 10mm nut and repositioning the bit. Quote Link to comment Share on other sites More sharing options...
Newlupo1 Posted February 14, 2018 Author Report Share Posted February 14, 2018 ok thanks. i guess then. its reachable with the panel removed..will have another go as i was unable to see the start of the cable from being upside down Quote Link to comment Share on other sites More sharing options...
