Azim Posted September 2, 2017 Report Share Posted September 2, 2017 Ive got a lupo sport that ive changed the gearbox on . Im having trouble selecting between 1st and 3rd gear cleanly . The 1st and 3rd gear seem to be very close together . When im trying to select 1st gear i often find that i have selected 3rd gear ,so i try again and then i can select 1st gear . I also find that its not easy to push the gearstick freely into those gears . I brought the second hand gearbox from a reputable breaker and it was sold with it working as it should . So i think the gearbox is hopefully fine . What do you guys think ?. Quote Link to comment Share on other sites More sharing options...
FlipFlops Posted September 2, 2017 Report Share Posted September 2, 2017 Can you adjust the gearstick throw/movement via the gear linkages in the engine bay? I'm sure you can adjust these. I've can on my Golf. Quote Link to comment Share on other sites More sharing options...
Rich Posted September 2, 2017 Report Share Posted September 2, 2017 you can. also check the alloy bracket on the back of the box which supports the linkages isn't broken, cracked, bent etc... Quote Link to comment Share on other sites More sharing options...
