Mikey444 Posted June 6, 2017 Report Share Posted June 6, 2017 Cars been sitting for a while drove it for about 3 miles now i've got this noise from the steering video attached IMG_3714.mp4 Quote Link to comment Share on other sites More sharing options...
Mobieus_uk Posted June 6, 2017 Report Share Posted June 6, 2017 (edited) Unable to hear file access restricted of somthingalong those lines First thing check the oil levels, when it goes low it starts to drag in air and makes the pumps noisey, if the levels are low then you have a leak My pump was noisy for 3 months before i bothered to look into it, found low oil levels, found leak, fixed leak and now the pump is fine and quiet again Edited June 6, 2017 by Mobieus_uk Quote Link to comment Share on other sites More sharing options...
Mikey444 Posted June 6, 2017 Author Report Share Posted June 6, 2017 Found a leak, topped it up so i will need to get it fixed, its leaking from the pipe that connects to the rack Quote Link to comment Share on other sites More sharing options...
Mobieus_uk Posted June 7, 2017 Report Share Posted June 7, 2017 sounds very similar to mine not sure about your hose configuration, but the sdi was a bit of a pig but had a new hose made up Quote Link to comment Share on other sites More sharing options...
