Rhysgrainger Posted January 24, 2017 Report Share Posted January 24, 2017 Hi all. Im looking for a drivers side outer sill for my 04 lupo 1.0E. The previous owner crashed the drivers side of the car and had it cheaply repaired, and over time, rust has gotten to the outer sill of my car. Is there any way i can repair this myself or wil i have to search for a replacement part? If so, does anyone have an outer drivers side sill? Thanks all. 1 Quote Link to comment Share on other sites More sharing options...
Rich Posted January 24, 2017 Report Share Posted January 24, 2017 chop chop in a scrappy time? Quote Link to comment Share on other sites More sharing options...
Rhysgrainger Posted January 24, 2017 Author Report Share Posted January 24, 2017 what? 1 Quote Link to comment Share on other sites More sharing options...
danno Posted January 24, 2017 Report Share Posted January 24, 2017 It means, 'is it time to chop one out in a scrapyard?'. Quote Link to comment Share on other sites More sharing options...
Rich Posted January 24, 2017 Report Share Posted January 24, 2017 I meant it is time. the lupo sill is a panel with the whole side. I don't think they're available separately. Quote Link to comment Share on other sites More sharing options...
mk2 Posted January 24, 2017 Report Share Posted January 24, 2017 You'll have to get a thin angle grinder blade and slice out the offending section and then do the same on a donor car. Then seam weld all along the join. Then grind off any excess, prime and fill till its all nice again. Then respray. You'll also have to pump a load of waxoyl into the sill cavity to stop it rusting from the inside out... Its quite time consuming work. Quote Link to comment Share on other sites More sharing options...
Rich Posted January 25, 2017 Report Share Posted January 25, 2017 reshell! Quote Link to comment Share on other sites More sharing options...
Derv Posted January 30, 2017 Report Share Posted January 30, 2017 Rich is right, the sill is part of the whole bodyside. So even if you bought a new one, you would still need to get the angle grinder out. Quote Link to comment Share on other sites More sharing options...
Sausage Posted August 21, 2018 Report Share Posted August 21, 2018 H'mmm: https://www.ebay.co.uk/itm/HQ-VW-LUPO-SEAT-AROSA-98-05-REPAIR-PANEL-SILL-GALVANISED-STEEL-SET-OF-2-Pair/273339723051 Who knows what sort of fit you'd get out of these or if they are over sills or replacements. The 1.4s needs sill work as they are pretty bent up and rusty, probably just be making repair patches and dent pulling though. Quote Link to comment Share on other sites More sharing options...
