Little tank Posted December 18, 2016 Report Share Posted December 18, 2016 (edited) Hi. My 52 plate 1.7 sdi, starts fine just wont stay on. any ideas? Runs for a second or two then cuts out. Don't think it has an immobiliser, but feels like something is cutting it out. Using search tells me about a stop solenoid, Anyone know where it is or how to test it? Edited December 18, 2016 by Little tank Quote Link to comment Share on other sites More sharing options...
Sausage Posted December 18, 2016 Report Share Posted December 18, 2016 (edited) http://www.myturbodiesel.com/images/fuelshutoffsolenoid.jpg 12v at the solenoid with ignition on, it's a electromagnetic plunger so volts makes it lift the plunger and let the fuel flow, off makes it stop the fuel flow. test for constant 12v with ignition on or engine running, if so you should feel it click when switched on of off, may have to remove it and bench test to check it properly. Edited December 18, 2016 by Sausage Quote Link to comment Share on other sites More sharing options...
Little tank Posted December 18, 2016 Author Report Share Posted December 18, 2016 Thanks for that. link doesn't work for me. Quote Link to comment Share on other sites More sharing options...
Sausage Posted December 18, 2016 Report Share Posted December 18, 2016 (edited) Not sure why it doesnt show up, it's a picture of an injection pump showing where the stop solenoid is. it is usually above the 4 metal fuel pipes coming out of the fuel pump and will have a wire going to it. Edited December 18, 2016 by Sausage Quote Link to comment Share on other sites More sharing options...
Little tank Posted December 18, 2016 Author Report Share Posted December 18, 2016 Got it, thanks. there's no power to the solenoid, is there a fuse or relay somewhere? Quote Link to comment Share on other sites More sharing options...
Mobieus_uk Posted December 18, 2016 Report Share Posted December 18, 2016 there is a relay above the fuses from memory its the one marked up 109 you can see it just hiding behind a wiring loom, its a pig to get to when the dash is all fitted Quote Link to comment Share on other sites More sharing options...
Mobieus_uk Posted December 18, 2016 Report Share Posted December 18, 2016 here the link to my post when i had problems with my 109 relay Quote Link to comment Share on other sites More sharing options...
Little tank Posted December 18, 2016 Author Report Share Posted December 18, 2016 Great, thanks for the help. I'll get a 109 relay. Quote Link to comment Share on other sites More sharing options...
Mobieus_uk Posted December 18, 2016 Report Share Posted December 18, 2016 43 minutes ago, Little tank said: Great, thanks for the help. I'll get a 109 relay. wouldn't rush out and buy one until you have confirmed the old has failed, nothing worse than buying parts you don't need I think when mine failed one of the symptoms was a glow coil light that flashed for about a fraction of a second, I could predict when the engine would start as when the glow coil light stayed of for a longer time it always started Quote Link to comment Share on other sites More sharing options...
