Serge Posted July 12, 2016 Report Share Posted July 12, 2016 Hello! I bought VW Lupo 1,4 16V engine AUA when I moved to the UK and it was a couple of month ago. I have a problem with the car. VCDS shows that there is a misfire in cylinder #1, but a very strange misfire. It only appears in the mornings and when the car is absolutely cold. It starts around 900-800 rpm and goes away when the engine is hot (but after erasing DTC) I changed a spark plug, ignition leads, ignition module, detonation sensor, temperature sensor. Compression is good. Manifold is checked, everything is checked and not only by me. I took the car to a several garages, nobody can find the reason. I'm really frustrated and don't know what to do. There are no errors except this one: Chassis Type: 6X (6X - VW Lupo (1998 > 2006)) Scan: 01 02 03 08 15 17 19 25 35 37 44 45 55 56 VIN: WVWZZZ6XZ1W050738 Mileage: 73210km-45490miles ------------------------------------------------------------------------------- Address 01: Engine Labels: 036-906-034-APE.lbl Part No: 036 906 034 AR Component: MARELLI 4LV 3634 Coding: 00003 Shop #: WSC 01236 VCID: 62D3BD03244F412269B4ECD-4B4C WVWZZZ6XZ1W050738 VWZ1Z0Y1005454 1 Faults Found: 16685 - Cylinder 1 P0301 - 35-00 - Misfire Detected I also checked EGR Valve and cleaned the EGR pipe, though it was relatively clean. {Please, help me, maybe somebody has an idea or had smth similar. Thanks Quote Link to comment Share on other sites More sharing options...
