BioTriffid Posted April 20, 2016 Report Share Posted April 20, 2016 Hi guys Just have a question I've had my car since September and I've been driving it for a while now and it's hard to explain the problem. If I'm doing 70mph the Revs are very high 4000-4500 rpm. I'm thinking at some point it's had a wrong gearbox fitted to it and wondered if anyone could help me out. If needed ill get a video of the clocks Thank you Kieran Quote Link to comment Share on other sites More sharing options...
carrera-gt Posted April 20, 2016 Report Share Posted April 20, 2016 You need to find the gearbox code to be sure of what's there, There are many versions of the 085 box it could be Trying to identify it from in gear speeds is nigh on impossible, even with a gear chart it's difficult because many 085 boxes use such similar ratios. Quote Link to comment Share on other sites More sharing options...
BioTriffid Posted April 20, 2016 Author Report Share Posted April 20, 2016 20 minutes ago, carrera-gt said: You need to find the gearbox code to be sure of what's there, There are many versions of the 085 box it could be Trying to identify it from in gear speeds is nigh on impossible, even with a gear chart it's difficult because many 085 boxes use such similar ratios. I hope it's just a gearbox that's off a 1ltr or something because it shouldn't be doing what it is. I'll look for the codes tomorrow and post them with a photo Quote Link to comment Share on other sites More sharing options...
christophertr6 Posted April 21, 2016 Report Share Posted April 21, 2016 My1.0 SE does around an indicated 80 mph with around 4200rpm showing. (approx.) Quote Link to comment Share on other sites More sharing options...
