Water leaking into car
flyboy
If any one is having trouble with water leaking in to their car, have a look at attached photo, I have taken the shroud off that that goes around the wheel arch and found it all silted up almost to the hole "arrowed" ,this hole goes into the cab so when it rained the water goes straight through the hole.
Cleared all the silt way and have had no problems since.
By the way I had the same problem on the passenger side and have cured tis as well.
Hope this helps someone else.
