tom01997 Posted April 1, 2016 Report Share Posted April 1, 2016 Hi all After getting hold of and installing some JOMs this week and going for an alignment & camber adjustment, my mechanic said he couldn't adjust the camber any better than -2*06' left front and -1*20' right front. I read somewhere on here a while back that using M10 bolts instead of the stock M12 one on the top of the two strut-hub bolts will allow a little more wiggle room. Is this generally considered the best way of getting more camber adjustment with joms? They do have oval shaped bolt holes already, so I wouldnt be too sure of filing out any more than they already are. Cheers, Tom. Quote Link to comment Share on other sites More sharing options...
mattarosa Posted April 6, 2016 Report Share Posted April 6, 2016 I don't have a clue but M10s wouldn't fit the M12 thread, they would just wobble around all over the place and you wouldn't be able to tighten them. Quote Link to comment Share on other sites More sharing options...
lupogtiboy Posted April 7, 2016 Report Share Posted April 7, 2016 My 'temporary' JOMs on my GTI had to be fitted with M10 nuts and bolts on the top holes, as I couldn't get decent camber any other way. These are done up 'FT', been told its bit of a sod to do though when it comes to alignment.... Quote Link to comment Share on other sites More sharing options...
tom01997 Posted April 7, 2016 Author Report Share Posted April 7, 2016 Even if it's a sod, at least it fixes the camber being out - would you recommend it long term or am I better off just leaving it is how it is now? Oh, and am I right to assume GTI fronts are largely the same to non GTI with regards to suspension? mattarosa - sorry I should have said M10 bolts... and nuts to go with them Thanks! Quote Link to comment Share on other sites More sharing options...
mattarosa Posted April 7, 2016 Report Share Posted April 7, 2016 That would explain it! Quote Link to comment Share on other sites More sharing options...
