Little John Posted February 25, 2016 Report Share Posted February 25, 2016 My interior light will not operate when I open the n/side door. Where is the operating switch? Quote Link to comment Share on other sites More sharing options...
lupogtiboy Posted February 26, 2016 Report Share Posted February 26, 2016 It is built into the door lock, so will probably need a new door lock. You can buy these on Ebay for around £20-£25 ish Quote Link to comment Share on other sites More sharing options...
Little John Posted February 26, 2016 Author Report Share Posted February 26, 2016 My Lupo is basic, 2door with no central locking to go wrong! Quote Link to comment Share on other sites More sharing options...
lupogtiboy Posted February 26, 2016 Report Share Posted February 26, 2016 Its still in the door lock, though I don't think the most basic ones do turn the light on from the passenger side, though I could be wrong about that. Quote Link to comment Share on other sites More sharing options...
Little John Posted February 26, 2016 Author Report Share Posted February 26, 2016 It has for the las 16 years! Quote Link to comment Share on other sites More sharing options...
christophertr6 Posted February 27, 2016 Report Share Posted February 27, 2016 There is a micro switch in the door lock - whether its central locking or not. My SE had the same issue. This micro switch also turns on the buzzer when you open the door with the lights on. If you remove the door lock you will have to unclip and electrical plug - and the wires will lead you to the micro switch. Its fixed to the lock by melted plastic rivets. With a scalple or soldering iron you can remove the switch. Its possible to get into the switch and clean out the crap that builds up inside it. The photo above shows the switch when its apart. Its delicate stuff, but I fixed mine with a pin. Way too hard to explain, but it will become obvious if you get the thing apart...............or just buy another lock on eBay.............or maybe from me if I can find the spare I think I've got. Quote Link to comment Share on other sites More sharing options...
Little John Posted February 28, 2016 Author Report Share Posted February 28, 2016 So it's the micro switch in the n/side door then? I assume that both doors have the switches? Quote Link to comment Share on other sites More sharing options...
christophertr6 Posted February 28, 2016 Report Share Posted February 28, 2016 Pretty sure. The interior light should respond to the passenger door opening - does on mine, so there has got to be a switch somewhere. I know that mine has one. There are guides on here somewhere as to haw to take the door lock out. Simple if you have the right tools - think its an 8mm spline drive bit of the lock body and a T20 torx for the barrel release (someone correct me if I'm wrong). Quote Link to comment Share on other sites More sharing options...
