Ropers101 Posted February 22, 2016 Report Share Posted February 22, 2016 Hi guys does anybody have any suggestions on what I can use to tackle rust on the outer parts of my disks. It looks so bad and the brakes have only been on the car for a few weeks. Also does anyone know where the correct positioning is for xenons? I've adjusted then manually but ideally I would like them the way they should be as I've just guessed. Thanks Quote Link to comment Share on other sites More sharing options...
Sausage Posted February 22, 2016 Report Share Posted February 22, 2016 A wire brush and some high temperature paint on the brakes if that bothers you, but dont paint the swept braking area. For the lights find some level ground with a wall and park dead on facing the wall about 10 foot away in the dark and adjust them, slightly down and to the left on dipped beam. MOT test will correct the beam if it's far enough out. Quote Link to comment Share on other sites More sharing options...
imaparana Posted February 23, 2016 Report Share Posted February 23, 2016 I think to do them properly they need to be plugged into a machine and set that way, jacksons is where id go even though they'd charge you an arm and a leg Quote Link to comment Share on other sites More sharing options...
