Steph4n Posted February 21, 2016 Report Share Posted February 21, 2016 Hey Ive been on this forum for a while and never made an account so I finally decided to and I'm stuck so I'm hoping somebody can help me? (I will be making a thread about my story of my lupos and now this arosa, I have a misfire problem on my 04 1.4 Arosa S and I would appreciate suggestions on how to fix it.. Steps I have taken so far are; Changed HT Leads Changed Spark Plugs Changed Coilpack i have also tried disconnecting the battery and waiting to remove the engine management light and it worked and the car seemed a lot better but then it came back flashing disappeared again then came back and stuck and I'm back to square one all advise is appreciated, thanks. Quote Link to comment Share on other sites More sharing options...
Ironflitz Posted February 21, 2016 Report Share Posted February 21, 2016 Do a compression test and you'll be able to diagnose if it's an internal problem or not. Search Google on how to do one, there's a detailed one on vauxhall owners club. Ironflitz. Quote Link to comment Share on other sites More sharing options...
Steph4n Posted February 21, 2016 Author Report Share Posted February 21, 2016 7 minutes ago, Ironflitz said: Do a compression test and you'll be able to diagnose if it's an internal problem or not. Search Google on how to do one, there's a detailed one on vauxhall owners club. Ironflitz. I have been told this if it's not compressing properly is it an easy fix or is it going to cost a lot? Quote Link to comment Share on other sites More sharing options...
Skezza Posted February 22, 2016 Report Share Posted February 22, 2016 14 hours ago, Steph4n said: I have been told this if it's not compressing properly is it an easy fix or is it going to cost a lot? If it's not compressing properly, then you've potentially got big problems mate. Quote Link to comment Share on other sites More sharing options...
Sausage Posted February 22, 2016 Report Share Posted February 22, 2016 (edited) As said already get a compression test done or cheaper still buy a compression tester and do it yourself. (about £20) read up on the internet how to do it and post the results with 10 seconds cranking and wide open throttle on each cylinder. have you used a code reader to see what the faults are? Edited February 22, 2016 by Sausage 1 Quote Link to comment Share on other sites More sharing options...
Steph4n Posted February 24, 2016 Author Report Share Posted February 24, 2016 Cylinder 2 is not compressing properly maybe a loose valve so get top end taken apart and looked at replacing head gasket and belt whilst it's being done aswell can't wait to see the bill Quote Link to comment Share on other sites More sharing options...
