Little tank Posted January 25, 2016 Report Share Posted January 25, 2016 Hi, just had the cambelt and thermostat change at a garage. when I got home looked under the bonnet and the coolant had leaked and was over the max. The car came nicely up to temp. didn't over heat. I drained the coolant back to max. With the car running at operating temp and cap off, I squeezed the top and bottom rad hoses abit to try to get any air out. I put the heaters to max while doing this. the coolant stayed at max level. When I got back in the car the temp was at zero. any help to why this might be??? Quote Link to comment Share on other sites More sharing options...
Little tank Posted January 25, 2016 Author Report Share Posted January 25, 2016 Hang on just reading about blocking the grill. it is an sdi. Quote Link to comment Share on other sites More sharing options...
