iSutehall Posted January 22, 2016 Report Share Posted January 22, 2016 Okay, so I've owned my GTI over a year, and recently I've been having problems with the leveling of the xenons... I manually adjust them and within a few days they either drop or they raise themselves? Would this be problem with the self leveling sensor on the rear beam? Or would it be a problem with the motor for the lights? Quote Link to comment Share on other sites More sharing options...
lupogtiboy Posted January 22, 2016 Report Share Posted January 22, 2016 I think to correctly adjust them, they need a beam level setter like on an MOT ramp, and VAGCOM or VCDS. Quote Link to comment Share on other sites More sharing options...
Lupoboz Posted January 22, 2016 Report Share Posted January 22, 2016 (edited) 11 hours ago, iSutehall said: Okay, so I've owned my GTI over a year, and recently I've been having problems with the leveling of the xenons... I manually adjust them and within a few days they either drop or they raise themselves? Would this be problem with the self leveling sensor on the rear beam? Or would it be a problem with the motor for the lights? There could be an issue with the levelling sensor(s). One way to check is to see if the motor makes a noise with the headlamps switched on, the engine has to be running in order for you to check this. I have one levelling motor in stock (brand new, genuine part) should you need it. £53.36 retail, Club Member price £25.00 inc postage. Regards, Dale. Edited January 22, 2016 by Lupoboz Quote Link to comment Share on other sites More sharing options...
CLAYTONJONES Posted January 22, 2016 Report Share Posted January 22, 2016 Did you use VCDS to tell the Xenons they are being adjusted? Quote Link to comment Share on other sites More sharing options...
iSutehall Posted January 22, 2016 Author Report Share Posted January 22, 2016 Lupoboz, will check that soon! If any problems might end up buying a new sensor from you! And Clayton, I've not used VCDS yet will try and get hold of one and see what it says! Quote Link to comment Share on other sites More sharing options...
CLAYTONJONES Posted January 22, 2016 Report Share Posted January 22, 2016 12 minutes ago, iSutehall said: Lupoboz, will check that soon! If any problems might end up buying a new sensor from you! And Clayton, I've not used VCDS yet will try and get hold of one and see what it says! You need VCDS to tell the xenons they are being adjusted otherwise they will go back to there last position, Quote Link to comment Share on other sites More sharing options...
