BioTriffid Posted January 7, 2016 Report Share Posted January 7, 2016 Radio I'm gonna put in 7 inch touchscreen display Satnav, tv , dvd, rear camera and radio And a whole load of wires to put in but should be easy enough to fit Quote Link to comment Share on other sites More sharing options...
Skezza Posted January 8, 2016 Report Share Posted January 8, 2016 A good old China 2DIN. You can't beat them (well you can, but not for the money). I've had nothing but pleasurable experiences with China 2Din's, don't let the big brand morons put you off. Your biggest challenge will be fitting all the wiring and gubbings and stuff behind the head unit, so I'll give you some tips to help you out. Firstly imo, don't fit the rear camera, just isn't worth it, I mean we're talking a Lupo, if you do decide to fit it, I'd run the wiring down the DRIVERS SIDE, as opposed to the passenger side. There's a channel where you can run it free from any interference, which is where most of the wiring for the rear electricals runs. For your GPS antenna, two options, you can drop it down the middle console, retrieve it at the bottom then route it around up past your pedals and up behind the dashboard. It's quite hard and stressful though, or route it via the passenger side which is equally stressful. Alternatively, route the GPS antenna under the cubby underneath the radio, bring it out and then run the cable under the dash that way. You'll have a small amount of cable exposed under the dash but you won't see it. You're going to have a lot of excess wiring back there so you'll want to decide what RCA's you need carefully, if any at all. The more RCA's, more cabling, the less chance it'll fit nicely. To make some extra space, the rear of the head unit bracket has a T-Bar going across it. You can happily break (cut in my case) this off using a dremel or brute force. It's only for the OEM radio and it doesn't really do anything. It's primarily there for the rubber buffer at the back of the OEM radio which sits in it, perhaps to reduce vibrations? The OEM radio will still go back in without it though, so I'd personally get rid of It. Finally, forget using a cage, get yourself an FP-17-00. Quote Link to comment Share on other sites More sharing options...
BioTriffid Posted January 8, 2016 Author Report Share Posted January 8, 2016 thanks for the advice mate ill get round to fitting it soon and ill post and update here kieran Quote Link to comment Share on other sites More sharing options...
mattarosa Posted January 8, 2016 Report Share Posted January 8, 2016 One thing... Reversing camera, on a lupo? With wing mirrors and a rear view mirror? Not being funny I have a 24v full colour camera to mount somewhere off a dump truck Quote Link to comment Share on other sites More sharing options...
BioTriffid Posted January 8, 2016 Author Report Share Posted January 8, 2016 not to sure if ill use it or install it but it could have its up sides to having one Quote Link to comment Share on other sites More sharing options...
Skezza Posted January 8, 2016 Report Share Posted January 8, 2016 If you want to fit it go right ahead, sometimes it's fun to do things for shits and giggles. Should be real easy on the Lupo as well Quote Link to comment Share on other sites More sharing options...
cj1 Posted January 10, 2016 Report Share Posted January 10, 2016 On 8 January 2016 at 0:57 PM, Skezza said: I'd run the wiring down the DRIVERS SIDE, as opposed to the passenger side. There's a channel where you can run it free from any interference, which is where most of the wiring for the rear electricals runs. The rear wiring all runs down the passenger side... Quote Link to comment Share on other sites More sharing options...
Skezza Posted January 11, 2016 Report Share Posted January 11, 2016 10 hours ago, cj1 said: The rear wiring all runs down the passenger side... Not true. The wiring for the micro switch and internal lights is run down the drivers side. Rear lights is run down the passenger side. Quote Link to comment Share on other sites More sharing options...
cj1 Posted January 11, 2016 Report Share Posted January 11, 2016 5 hours ago, Skezza said: Not true. The wiring for the micro switch and internal lights is run down the drivers side. Rear lights is run down the passenger side. In which case your comment wasn't true either. "most of the wiring" does not run down the channel on the drivers side. Anyway, I'd have thought running the cables down the passenger side would be easier though as you've not got the instruments etc... in the way initially, and it's easier to get the trim off where the boot handle would be on the drivers side. Quite a bit easier, especially if you tie the cables to something a bit more substantial first, like an unfolded metal coat hanger, or a bicycle brake cable outer. . Quote Link to comment Share on other sites More sharing options...
