TheFish Posted October 19, 2015 Report Share Posted October 19, 2015 After much internet searching, I can't specifically find where the thermostat is? Has anyone changed one? How complex is it? I assume the rad has a temp sensor, then the actual thermostat is anywhere really....My thermostat takes a good 15-20 mins to get to 90, but it also goes up and down a bit first....once at 90 it's fine. Just seems odd behaviour as have had a few tdis but never had this, so if an easy job, I will just do it as part of ongoing mid life refurb work.....it's an 02 with 76k....Any pointers? Quote Link to comment Share on other sites More sharing options...
Sausage Posted October 19, 2015 Report Share Posted October 19, 2015 (edited) you didnt search very hard then did you to be fair there isnt much lupo stuff out there, i end up using polo mk3 or skoda fabia manuals.http://workshop-manuals.com/skoda/fabia-mk1/power_unit/1.4/51;_55;_59_kw_tdi_pd_engine/engine_cooling/cooling_system/removing_and_installing_coolant_regulator/Reasonably sure lupo will be similar. Edited October 19, 2015 by Sausage Quote Link to comment Share on other sites More sharing options...
Rich Posted October 20, 2015 Report Share Posted October 20, 2015 You need to take the alternator off. . .. . 1 Quote Link to comment Share on other sites More sharing options...
Dblock Posted October 20, 2015 Report Share Posted October 20, 2015 That's sure a hard way of doing it. Quote Link to comment Share on other sites More sharing options...
Rich Posted October 20, 2015 Report Share Posted October 20, 2015 There's an easier way? Quote Link to comment Share on other sites More sharing options...
jon_273 Posted October 20, 2015 Report Share Posted October 20, 2015 Yes, use a knuckle joint on the socket. Mine has A/C, but if anything I would have thought that would make changing the thermostat even harder as there are more things in the way. 1 Quote Link to comment Share on other sites More sharing options...
jon_273 Posted October 20, 2015 Report Share Posted October 20, 2015 This is my car. Maybe it's different because of the a/c but I changed the thermostat without removing the alternator. And it was a waste of time anyway, it didn't make it warm up any faster! Quote Link to comment Share on other sites More sharing options...
TheFish Posted October 20, 2015 Author Report Share Posted October 20, 2015 Thanks all for the pointers.....the skoda link looks great to know where to look/do etc.....really good, thanks Quote Link to comment Share on other sites More sharing options...
Dblock Posted October 21, 2015 Report Share Posted October 21, 2015 Yes, use a knuckle joint on the socket. Mine has A/C, but if anything I would have thought that would make changing the thermostat even harder as there are more things in the way.I did it the same way. Like Rich doesn't know lol. He's probably forgotten more than I know. Quote Link to comment Share on other sites More sharing options...
Skezza Posted October 21, 2015 Report Share Posted October 21, 2015 I did it the same way. Like Rich doesn't know lol. He's probably forgotten more than I know. and me. Quote Link to comment Share on other sites More sharing options...
Rich Posted October 21, 2015 Report Share Posted October 21, 2015 tbf it's been on my to do list for about a year now so I might get around to it soon.I didn't bother swapping it over when I changed the engine. Quote Link to comment Share on other sites More sharing options...
TheFish Posted November 11, 2015 Author Report Share Posted November 11, 2015 All done. Had the car stripped in about 20-30 mins. Raised the front and chocked.Battery disconnected.Engine cover off.Hose clamp off top black hose and undid electrical connector.Undid 2 screws on air box to allow 2 black hoses to lift clearPlug off alternatorBig nut off alternatorSmall 8mm nut off alternator16mm spanner on tensioner node/knobbly bit and pulled forward, slipped off toothed beltUndid 3 bolts on tensioner and removed itPut cardboard and bubble wrap on radiator in front of alternator Swing alternator downLoosened lower but removed 2 x long bolts on alternatorRemoved bottom tray, 2x 13mm bolts under enginePlaced washing up bowl under engineUndid 2 bolts on thermostat, fluid outRemoved black plastic hoseshoe clip on sender (pull down)Wiggle out sensor, big gush of fluid from thermostat! Release cap on resovoir, all fluid out (less balance in radiator)Disconnect sensor from plugFitting is the reverse! Ensure toothed belt is sat flush on the pulleys. If it falls why positioning the lower one, just hold in place with tape, remove and check...., Quote Link to comment Share on other sites More sharing options...
