SimonJ65 Posted October 1, 2015 Report Share Posted October 1, 2015 Other than being red are the GTi calipers different to the Sport front calipers? I know the GTi brake discs are 25mm thick and the Sports are 20mm but can the thicker disc be used with the Sport calipers? Quote Link to comment Share on other sites More sharing options...
christophertr6 Posted October 18, 2015 Report Share Posted October 18, 2015 My GTI has Lucas 54 calipers - they are clearly marked on the outside. Assuming that there is only one spec for these then check if your car has them. If changing things around it would be advisable the check on pad thickness. I think the GTI pads are 15.6mm in thickness (new) but there are thicker pads available, so when using with thinner 20mm disc then thicker pad would make sense.If anyone else knows more specific facts then please wade in. Quote Link to comment Share on other sites More sharing options...
