wehey Posted August 26, 2015 Report Share Posted August 26, 2015 Hiya allI went to adjust the slack out the gear linkage cables and am unable to lock off the selector at the gearbox end. You are supposed to press down on the mechanism then twist the locking pin around 90 degrees to lock it in position before adjusting the cable slack. But the the mechanism just isn't locking up.Any ideas?? Quote Link to comment Share on other sites More sharing options...
wehey Posted August 27, 2015 Author Report Share Posted August 27, 2015 Problem now sorted Quote Link to comment Share on other sites More sharing options...
Dblock Posted August 29, 2015 Report Share Posted August 29, 2015 Did you use a drill bit to lock the shifter in the interior or not bother? Quote Link to comment Share on other sites More sharing options...
wehey Posted August 29, 2015 Author Report Share Posted August 29, 2015 Did you use a drill bit to lock the shifter in the interior or not bother?Yep. A 5mm drill bit did the trick Quote Link to comment Share on other sites More sharing options...
Rich Posted August 29, 2015 Report Share Posted August 29, 2015 I have a bent/snapped screwdriver which is perfect for it.Genuine mac item. Quote Link to comment Share on other sites More sharing options...
