Lupo ignition problems
Ropata
Did you say it does start eventually?
The pressing of the brake switch is very strange indeed. Makes me think it might be some kind of earthing issue, although I wouldn't rule out the ignition switch. I can see why James thought it was the battery because when my battery died I had similar experiences of the clocks clearing etc.
That said, I feel if the ignition switch was ballsed it shouldn't be clearing the clocks like that. It looks as though there is a short causing the current to drain which causes the fragging of the clocks.
Get the column off, let's have a look at the ignition switch.
