marybakers Posted May 2, 2015 Report Share Posted May 2, 2015 my fox 1.2 hatchback has a steering wheel yellow light come on in the dashboard,has anyone any idea what the problem is,much appreciated if you can help,what lights should light up on the dashboard when you start the engine.thanks Quote Link to comment Share on other sites More sharing options...
Skezza Posted May 5, 2015 Report Share Posted May 5, 2015 Pretty sure that means the steering wheel might be out of line with the power steering servo or something. I forget what it is, but I know when changing the steering wheel, the solution is to full lock from one side to the other then central. Quote Link to comment Share on other sites More sharing options...
