mk2 Posted December 28, 2014 Report Share Posted December 28, 2014 (edited) I think the tracking is out on my SDI. does anyone know what the camber and tracking angles should be? Toe in/out and postive or negative caster? I need to get a manual from somewhere! Thanks so much people. Edited December 28, 2014 by mk2 Quote Link to comment Share on other sites More sharing options...
Vwlup0 Posted January 2, 2015 Report Share Posted January 2, 2015 If you take it to a place that does tracking they will have all the numbers You can only adjust the front toe unless you get camber bolts for the front and shims for the rear. Caster usually changes when you adjust camber, but you'll rarely get them both bang on. Hope this helps! Quote Link to comment Share on other sites More sharing options...
mk2 Posted January 3, 2015 Author Report Share Posted January 3, 2015 If you take it to a place that does tracking they will have all the numbers You can only adjust the front toe unless you get camber bolts for the front and shims for the rear. Caster usually changes when you adjust camber, but you'll rarely get them both bang on. Hope this helps! Excellent idea. Thanks for that. Quick fit will probably have a book with the numbers.... Cheers Quote Link to comment Share on other sites More sharing options...
Reedo Posted January 4, 2015 Report Share Posted January 4, 2015 just had my tracking done toeing out by 2.5mm both sides. the car now has 0.5mm toe in. 0 camber btw Quote Link to comment Share on other sites More sharing options...
mk2 Posted January 5, 2015 Author Report Share Posted January 5, 2015 just had my tracking done toeing out by 2.5mm both sides. the car now has 0.5mm toe in. 0 camber btw I'll try the same setup. I noticed today when driving through a deepish puddle for the first time since getting the car, that it really pulled the car sideways. Very unexpected since i'm used to driving golfs which are very stable. Could be the cheap tyres or steering alignment though. Quote Link to comment Share on other sites More sharing options...
Deanb96 Posted May 26, 2015 Report Share Posted May 26, 2015 Did you guys put the camber put yourselves or get a garage to do so? Need tips for mine! Quote Link to comment Share on other sites More sharing options...
Reedo Posted June 2, 2015 Report Share Posted June 2, 2015 i got mine done by a garage Quote Link to comment Share on other sites More sharing options...
