seat arosa 1.0 s 2003 engine fault
  • Please log in to reply
14 replies to this topic
#1 lupo_matt
lupo_matt
  • Members
  • 5 posts
  • Currently Driving:2002 lupo gti
Posted 06 October 2011 - 07:35 PM
Hi my arosa has got a slight misfire and is a real pain to start, i have fitted new plugs and leads but its still the same also the engine managment light is on. Are there any common faults with these models?
Thanks matt
#2 Chrisbee
Chrisbee
  • Members
  • 493 posts
  • Gender:Male
  • Currently Driving:MK2 Arosa
Posted 06 October 2011 - 10:44 PM
coil pack, lumbda sensor will be next, unless you can run vag com on it?
#3 foto2021
foto2021
  • Members
  • 48 posts
  • Currently Driving:1997 Arosa 1.4 MPi auto
Posted 06 October 2011 - 10:45 PM
If the engine management light is on, it would be a good idea to get a technician with VAG-COM to have a look at it and diagnose the fault.
A simple VAG-COM diagnosis and reset of the ECU (engine management) fault codes should cost about £20. There are quite a few technicians advertising this service on eBay. Just find one close to where you live or work.
#4 Chrisbee
Chrisbee
  • Members
  • 493 posts
  • Gender:Male
Posted 07 October 2011 - 11:16 AM
The thing with vag com is it'll only give you a list of possible parts that will be fualty, so you have to work through the list anyway.
#5 Rich
Rich
    Member of the Year '11, '12 and 2013
  • Premium Member
  • 7512 posts
  • Gender:Female
  • Interests:Campaigning.
  • Currently Driving:Rapey Golf MKII.
Posted 07 October 2011 - 11:24 AM
17756, 17757.
I'll say those are the codes and they shouldn't be generated on a AUC engine.
Let me know if I'm right. :)
Vote Rich, member of the year 2015.
I recently decided that LisaGTI is not as hot with darker hair, blonde ftw/
th_smiley_jester.gif Official Clup Lupo Joker 2013 & 2014 th_smiley_jester.gif
#6 Silver!
Silver!
    Playground Monitor
  • Moderator
  • 16238 posts
  • Gender:Male
  • Interests:Compulsive hoarding and being a grumpy old man
  • Currently Driving:A Silver GTI and a Silver tractor...
Posted 07 October 2011 - 12:42 PM
Sounds like a lambda sensor problem. Does it smell of fuel when starting? Is it using more fuel than normal?
Posted Image
Posted Image
#7 Adam R4
Adam R4
    Best Arosa 2012 - Runner up.
  • Members
  • 1575 posts
  • Gender:Male
  • Interests:VAG, Motorsport & Photography
  • Currently Driving:Canica SEAT Arosa
Posted 07 October 2011 - 04:52 PM
I had a Misfire and my engine warning light on. Once it was on constant until i stoppped, left it over night and started it up in the morning and it had gone, Then as i was driving it started Really missing and the light was flashing then it was fine?
I got a friend to run his Fault reader on it, cleared the ecu and its been fine since.
Gave the plugs a clean up too, apparently good for 60k, mines only done 34.
SEAT Arosa | BBS RW 15x7 | Custom Coilovers | Pioneer Sound System | Best Arosa '12 Runner Up
Readers Ride Thread
Dub Candy - Join us on Facebook
#8 Chrisbee
Chrisbee
  • Members
  • 493 posts
  • Gender:Male
Posted 07 October 2011 - 04:59 PM
had a simular issue with mine, on a long run emisions light came on, vag com said it was an intermittent missfire in cylinder 1 and 2.
Check my ht leads and it would give me a shock if i touched the plug! ordered some new ones and noticed the old ones had been put in the wrong way round!
cars much more responsive now although i suspect my lamdba sensors are gunna need changing.
#9 Cannonball
Cannonball
  • Members
  • 145 posts
  • Gender:Male
  • Currently Driving:My mum mad. My real name is Arron Ball
Posted 07 October 2011 - 06:22 PM
If we are holding a raffle i'll have the ticket thats for the engine management temperature switch being or going faulty :thumbsup:
#10 craigg!!
craigg!!
  • Members
  • 189 posts
  • Gender:Male
  • Currently Driving:Mk2 Arosa Sport
Posted 07 October 2011 - 07:03 PM
I'll take a ticket for the coilpack please :P
But in all seriousness best to get a code reader on it to try pinpoint the fault rather than guessing a few posibilities.
#11 Rich
Rich
  • Premium Member
  • 7512 posts
  • Gender:Female
Posted 08 October 2011 - 01:40 AM
I'll take a ticket that I'm right.
#12 lupo_matt
lupo_matt
  • Members
  • 5 posts
Posted 11 October 2011 - 06:05 PM
its being read 2moro. The water temp rarely get above 70 degrees could this cause a fault? It does seem to be worse on fuel at the mo
#13 Cannonball
Cannonball
  • Members
  • 145 posts
  • Gender:Male
Posted 12 October 2011 - 07:57 PM
The ecu thinking the engine is cold will obviously be throwing more fuel at it all the time. That fuel could be fouling the plugs causing the miss and poor starting - only a guess which was why I opted for that sensor / switch ! Tomorrow will tell or at least begin to point you in the right direction.
Rich you can have that one only if you explain what " it " is :yes:
Good luck keep us updated it may help others :thumbup:
#14 lupo_matt
lupo_matt
  • Members
  • 5 posts
Posted 21 October 2011 - 12:42 PM
It was the ignition coil. It runs better now but it has a real low tickover of about 500rpm??
#15 lupo_matt
lupo_matt
  • Members
  • 5 posts
Posted 31 October 2011 - 08:13 PM
Anyone know the part number fro the map sensor? 2003 1.0 arosa
0 user(s) are reading this topic
0 members, 0 guests, 0 anonymous users
