wings123 Posted September 29, 2014 Report Share Posted September 29, 2014 Hey im a newbie here and need some advice. I've started my conversion and with the engine near enough ready to come out of lupo and that was the easy bit. My orginal plans were to buy a mk4 gti and use that however a 99 1.8t passat popped up for a few pound and took that ! now the problem im having is that its an AEB engine code and i wondering will it be the same job as a mk4 gti engine an could i use mk4 gti gearbox eg oj2 gearbox with this engine?Thanks for any advice Quote Link to comment Share on other sites More sharing options...
sam80quattro Posted October 23, 2014 Report Share Posted October 23, 2014 aeb engines sit the other way around so you will need golf manifolds/sump/oil pickup pipe possibly a few morre bits, yes the golf gearbox will bolt to the aeb, flywheel made need changed Quote Link to comment Share on other sites More sharing options...
baker1983 Posted October 29, 2014 Report Share Posted October 29, 2014 I've done a 1.8t audi awt engine which is same as aeb to a mk1 golf gti, I found the build easy as used 020 original gearbox and bought the engine mount, only extras needed are golf alternator carrier, tensioner and manifold the rest I used custom parts ie intercooler,intercooler pipes etcI'm currently doing a 1.8t in a lupo what the f**k have I let myself in for.Going to update some pics later Quote Link to comment Share on other sites More sharing options...
wings123 Posted November 4, 2014 Author Report Share Posted November 4, 2014 aeb engines sit the other way around so you will need golf manifolds/sump/oil pickup pipe possibly a few morre bits, yes the golf gearbox will bolt to the aeb, flywheel made need changedSorry ive crazt busy recently with work jsut started a new job and flat but ive managed to strip the lupo down engine jsut needs lifted out and passat will be ready to have the engine lifted out on wednesday night I've done a 1.8t audi awt engine which is same as aeb to a mk1 golf gti, I found the build easy as used 020 original gearbox and bought the engine mount, only extras needed are golf alternator carrier, tensioner and manifold the rest I used custom parts ie intercooler,intercooler pipes etcI'm currently doing a 1.8t in a lupo what the f**k have I let myself in for.Going to update some pics laterThats good to know because ive been told to scrap the AEB engine i dont want to do that as it is a nice clean engine running well, What engine mount did you use cause i though this would be a custom job? Ill make note of the extras and see if santa will bring a few of them will have to get a look at your thread thenThanks for the replys guys sorry took me so ling replying will be on more now things have settled down a bit Quote Link to comment Share on other sites More sharing options...
