Kirsty91 Posted September 1, 2014 Report Share Posted September 1, 2014 I need a little advice.I have a 1L arosa, recently the engine warning light has come on and sometimes will flash but it seems to idle lumpy,All leads, plugs and coil pack are newAny ideas??? Quote Link to comment Share on other sites More sharing options...
Skezza Posted September 1, 2014 Report Share Posted September 1, 2014 Could do with scanning it.Got a video? Quote Link to comment Share on other sites More sharing options...
pkrboo Posted September 2, 2014 Report Share Posted September 2, 2014 defo needs a scan with VCDS.But check that the leads are all connected properly. and no connectors are loose on any leads and cables near where the coil and leads are that could have been disturbed during the replacementBy the way i think i bought a retrosound stereo from you. Quote Link to comment Share on other sites More sharing options...
danoid Posted September 2, 2014 Report Share Posted September 2, 2014 What was the reason for changing sparks, leads & coil pack? Was it lumpy before you started?If so, then it could possibly be a vacuum leak, are your brakes okay? Quote Link to comment Share on other sites More sharing options...
Kirsty91 Posted September 7, 2014 Author Report Share Posted September 7, 2014 Sorry i didnt put much info in here.It was running iffy at times so plugged in and was a problem with no 3 so replaced everything and problem is still there and engine light is on. Also from time to time seems to have less power then it normaly does...and yes pkrboo you did haha, small world!!! Quote Link to comment Share on other sites More sharing options...
pkrboo Posted September 9, 2014 Report Share Posted September 9, 2014 Have you cleared the codes? Have any come back?Possibly do a compression test next Quote Link to comment Share on other sites More sharing options...
