Davedex Posted August 27, 2014 Report Share Posted August 27, 2014 I may have posted this in the wrong section firstly and maybe a moderator can remove the "wrong"one. My rev counter on my 1.0l year 2000 lupo is not going back to zero when the engine is turned off. It rests between 20 & 30 and when on tick over hovers just over the 30 mark. Obviously the engine is not doing this amount of revs.It suddenly started today for no reason. Can anyone help me please ? Quote Link to comment Share on other sites More sharing options...
HDH Posted August 30, 2014 Report Share Posted August 30, 2014 Common problem.It will eventually go down on it's own as it will go down a bit every time you turn the engine off. Don't be tempted to turn it on and off again repeatedly in a short space of time as you might damage something. Quote Link to comment Share on other sites More sharing options...
Davedex Posted September 1, 2014 Author Report Share Posted September 1, 2014 Yes you are fight, it did go down slowly by itself! Quote Link to comment Share on other sites More sharing options...
danoid Posted September 1, 2014 Report Share Posted September 1, 2014 http://forums.clublupo.co.uk/index.php?/topic/76328-how-to-gti-clocks-in-a-non-gti/May look daunting but it isn't, you can stop when the unscrew the back while panel, as when you lift it up, you'll be exposed to the front of the dials then Quote Link to comment Share on other sites More sharing options...
