vw_ Posted February 11, 2014 Report Share Posted February 11, 2014 Hello all need some knowledge! I've finally got round to wiring in my speakers and sub and im not sure how i can run my power wire for my sub to the amp in my boot. is there a rubber gromit or a hole for other wires i can push it through if so where ? vw lupo 1.4 16v 1999cheers Luke Quote Link to comment Share on other sites More sharing options...
shearermax Posted February 11, 2014 Report Share Posted February 11, 2014 with mine the power cable i ran underneath the carpet along the passenger side then if you pull the carpet and the sound proofing away from the foot well if you look up there is a gromit in there i think i just cut a little wholeand earth i put in the boot there is a grounding point on the left side under the carpet wall Quote Link to comment Share on other sites More sharing options...
vw_ Posted February 11, 2014 Author Report Share Posted February 11, 2014 i found a bolt that seemed to not be doing anything so i unscrewed it and left a hole just the right size for my wire! but its not a gromit. ahh isit sweet cheers Quote Link to comment Share on other sites More sharing options...
shearermax Posted February 13, 2014 Report Share Posted February 13, 2014 as long as there is bare metal you will be sound with the grounding use a light and have a good look around up in the footwell Quote Link to comment Share on other sites More sharing options...
