Mr.Badbrains
Lupo Gti, Recaros, bags, Exip Mega...
I think you need to sell your wheels firstly.
Got so much hate on these wheels so they are staying. ;)
Hate?!
In that case I should definitely take them off you, it’s for your own good!
cool;
On 08/06/2017 at 10:30 PM, Mr.Badbrains said:
I didn't like how the parking lights are in Lupos rear light, so since the lights are now all red, I moved them in the center. Now the blinker is where the fog lights used to be (fog light disabled).
Also color coded rear Sharan badge.
Waiting for 20mm spacers for the rears, 25mm poke too much.
where did you get this from?
The Sharan badge? Part number 7M3 853 630 A FDY from the dealer.
Thanks
Here is an easy and cheap fix for noisy window regulators. Whenever I closed the doors while windows were down there was a nasty rattle. Turned out the plastic sliders were worn out and loose.
Replaced those and greased the guides and its all good and silent.
...Btw who knows what is that black plastic thingy on the block behind the engine? Something to do with the crankcase breathing. There is some minor coolant and/or oil leak there.
Edited by Mr.Badbrains
What discs are they ? (Front)
Recaros painted with Furniture Clinic products. Changed the color from gray to light cream. Not quite sure what to do with the plastic parts but they are staying gray for now.
On 5/1/2018 at 10:12 AM, Mr.Badbrains said:
G60 front brakes and new rear discs and pads all around. And some interior bits.
41778843312_ed88f6276b_c.jpgDSC_6068 by Leevi Myyry, on Flickr
DSC_6070 by Leevi Myyry, on Flickr
41820616091_2771d3091f_c.jpgDSC_6074 by Leevi Myyry, on Flickr
Nice work fella - interested to see how you get on with the Brembo Max discs, was thinking of them myself to run with my Brembo calipers -thats if I can get them to fit under my rims
Is that a Dreadnaught gear knob on a short shifter?
Thank you. So far no complains with the discs. The gear knob is a one-off from CDIY. Made out of recycled skateboards.
Where can i find those? Didn't realise it was a problem until i saw this.
Ebay is where I got mine. Google lupo window regulator repair kit clips.
The brakes are starting to feel all ok after a few times of bleeding. There is still some air in the system I believe but the brakes bite a lot higher now than from where I started. A bigger master cylinder wouldn't be a bad idea.
28087179747_a3bbc4a6df_c.jpgDSC_6387
42063237865_b4c19358db_c.jpgDSC_6404
A few interior shots:
42915400202_e6a31512e1_c.jpgDSC_6397
29092442528_2cfce94b3c_c.jpgDSC_6400
42246648124_a3d60451b5_c.jpgDSC_6424
