Blue fox Posted September 22, 2013 Report Share Posted September 22, 2013 I have just purchased a vw fox and it's a little rough on tick over. Sometimes the engine starts to judder slightly as though it's gonna start to stall and when you push the accelerator it misses a little at the low revs before running better at slightly higher revs. I have changed the plugs, leads, coil pack, fuel filter but this has made no difference. I also cleaned the throttle body. I'm starting to run out of ideas if anyone can help ? I thought it was a misfire but I'm not so sure now. There are also no warning lights Quote Link to comment Share on other sites More sharing options...
Blue fox Posted October 17, 2013 Author Report Share Posted October 17, 2013 Just to let you know this turned out to be a failed piston and the engine needed repairing or changing. It was changed for 250 by me and now runs great. Not a hard job to change the engine. This was my first. Don't pay hundreds just give it a go. Quote Link to comment Share on other sites More sharing options...
